mikeyl
4 years agoQuartus Fitter Crashing
Hi, I'm looking to get some help to get my Quartus to work for my digital logic/comp org class. Its been giving me quite a headache. Currently I have the M1 Pro Macbook and I need to run Quartus usin...
aseel13
2 years agoi have the same exact problem could you help me please
dvirc
2 years agoWhats the error?
Which version of Quartus are you using?
Which OS?
If you're using Macbook with Apple silicon - I was able to overcome the issues using Parallels 19 or above with Win11 and Quartus 23.
Theres still an issue with MegaWizards on QP23 so for that I use QP22.
For ModelSim im using QP16.1.
Fortunately all the issues Ive seen can be solved by using multiple versions of QP over Win11 over Parallels 19 or above.
Which OS?
- aseel132 years ago
i attached the error. im using quartus prime lite 17 and i have macbook air M1 , im using parallels 19 and win11 , im not sure i understood what megawizards is .
- dvirc2 years ago
My guess is that its related to the fact that your working directory is located on your Mac which windows considers as remote / network address.
I suggest you try copying your project to your local virtual c:\ under any directory that is not "remote" for windows. For example: c:\Projects\your_project.
If that doesnt work I suggest you try openning your project using QP23.1 while still keeping QP17.1 for future compatibility issues.
I can share that im still zigzagging between QP17.1/22.1/23.1 lite because of compatibility issues.
