mikeyl
4 years agoQuartus Fitter Crashing
Hi, I'm looking to get some help to get my Quartus to work for my digital logic/comp org class. Its been giving me quite a headache. Currently I have the M1 Pro Macbook and I need to run Quartus usin...
aseel13
2 years agoi have the same exact problem could you help me please
- dvirc2 years ago
Whats the error?
Which version of Quartus are you using?
Which OS?
If you're using Macbook with Apple silicon - I was able to overcome the issues using Parallels 19 or above with Win11 and Quartus 23.
Theres still an issue with MegaWizards on QP23 so for that I use QP22.
For ModelSim im using QP16.1.
Fortunately all the issues Ive seen can be solved by using multiple versions of QP over Win11 over Parallels 19 or above.- aseel132 years ago
i attached the error. im using quartus prime lite 17 and i have macbook air M1 , im using parallels 19 and win11 , im not sure i understood what megawizards is .
- dvirc2 years ago
My guess is that its related to the fact that your working directory is located on your Mac which windows considers as remote / network address.
I suggest you try copying your project to your local virtual c:\ under any directory that is not "remote" for windows. For example: c:\Projects\your_project.
If that doesnt work I suggest you try openning your project using QP23.1 while still keeping QP17.1 for future compatibility issues.
I can share that im still zigzagging between QP17.1/22.1/23.1 lite because of compatibility issues.
