Quartus Fitter Crashing
I can't seem to reproduce the error. When I compile on Lite edition there are instances where I can compile successfully. But when I don't, I see different types of Internal Errors.
Do you constantly see the Internal Error posted above? Do you see "Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3270" every time you try to compile?
I am reporting this matter to engineering and will let you know of any updates.
Nurina
I tried with the newest Quartus lite version and it worked. I think we need to update software.
But there is few adaptation to do. For instance, install WSL for platform designer because, when the compilation procedure is working, there is some issues about that.
- mikeyl4 years ago
Sorry for the late replay as I've been busy with school. I've tried installing WSL on my virtual machine. But I've been getting an error with Ubuntu 20.04. Should I try a different version? Just a note, the error also pops up during the fitter stage.
- Nurina4 years ago
You could try the latest Lite version. Could you share a zipped file of your project?
Nurina
- Nurina4 years ago
We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
