Quartus Fitter Crashing
I can't seem to reproduce the error. When I compile on Lite edition there are instances where I can compile successfully. But when I don't, I see different types of Internal Errors.
Do you constantly see the Internal Error posted above? Do you see "Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3270" every time you try to compile?
I am reporting this matter to engineering and will let you know of any updates.
Nurina
- Nurina4 years ago
Could you share your project in a zipped file?
Nurina
- jmlarbaig4 years ago
I tried with the newest Quartus lite version and it worked. I think we need to update software.
But there is few adaptation to do. For instance, install WSL for platform designer because, when the compilation procedure is working, there is some issues about that.- mikeyl4 years ago
Sorry for the late replay as I've been busy with school. I've tried installing WSL on my virtual machine. But I've been getting an error with Ubuntu 20.04. Should I try a different version? Just a note, the error also pops up during the fitter stage.
- Nurina4 years ago
You could try the latest Lite version. Could you share a zipped file of your project?
Nurina
