BigHandsomeBee
5 years agoquartus_fit was unexpectedly terminated by signal 9
I'm using Quartus Prime Pro 21.2.
When I synthesized a design on Stratix 10, I got an error:
Error(20549): Current module quartus_fit was unexpectedly terminated by signal 9. This may be because ...
Nurina
5 years agoHi,
This error occurs due to exhaustive system resources usage. I believe your OS and memory is supported by Quartus. Does this happen to all the designs you try to compile? Can you attach a .qar file?
Nurina
majinfly
5 years agoHi
I have the same problem as him。
I'm using Quartus Prime Pro 21.1 and the device is Stratix 10, Error:
Error(20549): Current module quartus_fit was unexpectedly terminated by signal 6. This may be because some system resource has been exhausted, or quartus_fit performed an illegal operation. You can view system resource requirements on the System and Software Requirements page of the Intel FPGA website (https://fpgasoftware.intel.com/requirements/).
Archive project will also fail.
