10 years agoQuartus filters out essential parts of state machine?
Hi, Recently faced very strange issue in my design. I have state machine, which goes through multiple steps, and at the end there is kind of "Delay" state and "SetReady" state... Problem is...
10 years ago --- Quote Start --- If it fails in RTL simulation (not gate level) then that tells you there is something wrong with some code somewhere. --- Quote End --- Apparently it is, thanks. I found timing issue which only happened in that particular project. With the root problem, which is related to optimization: Originally I had my UART driver, which works fine for some random time ( 1 - 10 minutes, and then suddenly stuck. ExternalPullUp solution which preserves all states unoptimized, or running with SignalTap and monitoring some states fixes it. I suspect it should be something wrong with my code, but I spent 3 weeks debugging it and gave up.
