9 years agoQuartus failed to run inside Docker (Linux)
Hello! I'm trying to implement our small automated testing & build system inside company. To do so, we decided to use Docker and Debian 8.x as base image. I'm able to build my simple demo project ...
8 years agoGreetings!
I spent a couple days chewing on this, and eventually found https://github.com/chriz2600/quartus-lite. The interesting thing about their implementation is that they're using tcmalloc (http://goog-perftools.sourceforge.net/doc/tcmalloc.html) instead of the stock malloc, which is unusual enough that I had to try it. Sure enough, installing libtcmalloc-minimal4 and then LD_PRELOADing it did the trick:
export LD_PRELOAD=/usr/lib/libtcmalloc_minimal.so.4
${QUARTUS_PATH}/nios2eds/nios2_command_shell.sh ./build.sh -r ${_revision} -s ${_size}
I've also found it beneficial(?) to delete ${QUARTUS_PATH}/quartus/linux64/libboost_system.so, libccl_curl_drl.so, and libstdc++.so.6, leaving it to use the stock Ubuntu versions instead (which are installed by the build-essential package, I believe). This is mostly because of suggestions for solving another error: Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed!
Hopefully this is useful information! Everything is working great with Quartus 17.0 for me, so far.
