13 years agoquartus error
on cyclon IV E EP4CE115F29C7
i have a ddr controller module connected to altera internal ram. during compilation i get this: Error: Memory block iliamemory:inst4|altsyncram:altsyncram_component|altsyncram_joj2:auto_generated|ram_block1a15 uses a global signal on its clock-enable1 port. This is not allowed for this family. it just drives me nuts! my memory megafunction does not contain any clock-enable port. i just have a clock generated from pll and that clock goes into DDR controller aswell as in my altera RAM. when i double click the error it takes me here: ram_block1a15 : cycloneive_ram_block WITH ( CLK0_CORE_CLOCK_ENABLE = "none", CLK0_INPUT_CLOCK_ENABLE = "none", CONNECTIVITY_CHECKING = "OFF", LOGICAL_RAM_NAME = "ALTSYNCRAM", MIXED_PORT_FEED_THROUGH_MODE = "dont_care", OPERATION_MODE = "bidir_dual_port", PORT_A_ADDRESS_WIDTH = 9, PORT_A_DATA_OUT_CLEAR = "none", PORT_A_DATA_WIDTH = 1, PORT_A_FIRST_ADDRESS = 0, PORT_A_FIRST_BIT_NUMBER = 15, PORT_A_LAST_ADDRESS = 511, PORT_A_LOGICAL_RAM_DEPTH = 512, PORT_A_LOGICAL_RAM_WIDTH = 32, PORT_A_READ_DURING_WRITE_MODE = "new_data_with_nbe_read", PORT_B_ADDRESS_CLOCK = "clock0", PORT_B_ADDRESS_WIDTH = 9, PORT_B_DATA_IN_CLOCK = "clock0", PORT_B_DATA_OUT_CLEAR = "none", PORT_B_DATA_WIDTH = 1, PORT_B_FIRST_ADDRESS = 0, PORT_B_FIRST_BIT_NUMBER = 15, PORT_B_LAST_ADDRESS = 511, PORT_B_LOGICAL_RAM_DEPTH = 512, PORT_B_LOGICAL_RAM_WIDTH = 32, PORT_B_READ_DURING_WRITE_MODE = "new_data_with_nbe_read", PORT_B_READ_ENABLE_CLOCK = "clock0", PORT_B_WRITE_ENABLE_CLOCK = "clock0", POWER_UP_UNINITIALIZED = "false", RAM_BLOCK_TYPE = "M9K" ); one strange thing.. if i delete pll generated clock on the ddr controller. and connect it to a input port, then it compiles with no errors. what can i do? tried everything... 3 days iv been wrestling with this misterious error.
