17 years agoQuartus error
Hello, I am getting the following error in Quartus Error (10054): Verilog HDL File I/O error at crc.v(26): can't open Verilog Design File "../source/parameters.vh" How do I resolve th...
17 years ago --- Quote Start --- Hello, I am getting the following error in Quartus Error (10054): Verilog HDL File I/O error at crc.v(26): can't open Verilog Design File "../source/parameters.vh" How do I resolve this error. This is a .vh file that the synthesizer is complaining about. Please help. --- Quote End --- Hi, did you add the file to your project ? Project -> Add/Remove Files in Project Did you see your file listed in the Window ?
SSumm3
7 years agoHow do you add a .vh file in the project. I've tried the conventional way to add it (the same way that .v files are added by opening a file or adding a file in the settings of the project) but the files are not appearing.
