15 years agoQuartus error while compiling a reference design
When compiling the reference design "Interfacing a 267-MHz DDR2 SDRAM with an Arria II GX FPGA" with Quartus 10.1sp1 on CentOS 4.6, I get the following error message. It says the error is in a tcl file coming with the Quartus suite. What can I do for it? Thanks!
Error: Tcl error: ERROR: Compilation database is newer than the last call to "create_timing_netlist". Use the "delete_timing_netlist" Tcl command before using "load_report". while executing "load_report" invoked from within "if [is_project_open] { if {$options(qsf2sdc)} { post_message -type info "Migrating assignments from quartus_tan" set value [get_ini_var -nam..." (procedure "main" line 121) invoked from within "main" (file "/app2/altera/10.1/quartus/common/tcl/internal/qsta_default_script.tcl" line 1104)
