Quartus error 13223 during synthesis on IP file generated by Quartus
- ZAhma17 years ago
Hi Joanne,
Apologies but I was unable to look into this over the last two days.
So far I have tried
* Open the files in Quartus (using File->open)
** For this I get an error "Can't open encrypted file"
* Add failing files to project. (Project -> Add remove files)
** Same output ("cannot open vhdl file... ")
* Updated license server files according to this workaround: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2019/flexlm-software-error--version-of-vendor-daemon-is-too-old.html
So far no change in the output. I've attached the project file here.
Thanks!
--Zohair
- ZAhma17 years ago
Hi Joanne,
I've spoken with our Intel rep and we've found that there is something wrong with our license files. We were sent a test license to check and with that we are able to compile correctly. We are now investigating what's wrong with our license files.
I think this issue can be closed since this is not an issue with the tools themselves.
Thanks for your help!
--Zohair
