BLee15Occasional Contributor6 years agoquartus_eda crashes (core dump) very often. I have to clean my project before compile to prevent crash Core dump: Problem Details Error: Internal Error: Sub-system: WSC, File: /quartus/neto/wsc/wsc_port.cpp, Line: 409 m_port_info.num_of_dimensions() == 1 Stack Trace: 0x54a7: WSC_PORT::left_bit ...Show MoreHello.qar15 KB
KennyT_alteraSuper Contributor6 years agoCan you provide the exact steps that you have used? I try duplicate it on my side but failed.
BLee15Occasional Contributor to KennyT_altera6 years agoRestore archived projectStart compilation. This usually success.Modify top.sv; adding some whitespace would be enoughStart compilation. quartus_eda crashes about 2 out of 3 times.
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
