11 years agoQuartus does not support unresolved numbers from numeric_std!!!
I have just found that code using unresolved_unsigned is rejected by Quartus II (it is accepted by Modelsim). I tried including numeric_std_vhdl2008.vhd in my project, which resulted in syntax ...
11 years ago --- Quote Start --- What is this numeric_std_vhdl2008.vhd file you're talking about - its not a standard file. Are you sure you werent confusing quartus, because you're using 2008 code with a '93 compiler? grammer. Can we have some example code that isnt working for you? --- Quote End --- This simple code is undertood correctly by Modelsim, but fails to compile with Quartus II , with error message "Error (10482): VHDL error at test_unresolved_unsigned.vhdl(10): object "unresolved_unsigned" is used but not declared" I have checked that VHDL 2008 is selected in project options. library IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; entity test_unresolved_unsigned is port (a: in std_ulogic_vector(2 downto 0); b: out std_ulogic_vector(2 downto 0)); end entity; architecture test of test_unresolved_unsigned is signal a_unsigned, b_unsigned: unresolved_unsigned(2 downto 0); begin a_unsigned <= unresolved_unsigned(a); b_unsigned <= a_unsigned + 1; b <= std_ulogic_vector(b_unsigned); end;
