10 years agoQuartus did not work on 64-bit redhat enterprise linux 7.2
Downloaded and installed bittware software for opencl FPGA board.
1. installed bw2tk-1.9-20849.el7.x86_64.rpm 2. using bwconfig-gui, loaded top.rbf from hello_world_d5 to flash0 memory of device. 3. power cycle the machine 4. install quartus prime standard edition 15.1.0.185 by executing set.sh in AOCL-15.1.0.185-linux 5. install quartus prime standard edition 15.1.2.193 by executing QuartusSetup-15.1.2.193-linux.run 6. install AOCL 15.1.2 by executing AOCLSetup-15.1.2.193-linux.run 7. copied bittware opencl bsp to board/bittware path. 8. device is detected by linux. 9. when i run quartus --64bit i get error sed: /home/ram/altera/15.1/quartus/linux64/liblzma.so.5: no version information available (required by /lib64/libselinux.so.1) quartus: error while loading shared libraries: libpng12.so.0: wrong ELF class: ELFCLASS32 what is the solution for it?No RepliesBe the first to reply
