SO
8 years agoQuartus Design Partitions Crash - SR 00325624
This a continuation of SR 00325624. I'm trying to use Design Partitions to route a timing critical block containing a hard IP PCIe and DDR4 controller but when I reach the fit step, Quartus crashe...
SO
8 years agoDBay, thanks for the advice. I'm currently separating the partitions more logically by reworking my hierarchy maybe I'll stumble across something. I only moved to Q18 because I have the same problem in Q16.1.2 and knew the first question from support would be if I was using the latest Quartus.
KYeoh, I loaded up just the QAR file in a fresh folder and hit "Start Compilation". I get to FIT and it throws the same error "...Expected to get 1 pll but found 2 plls for group..." If I stop using partitions, everything compiles fine. It only seems to error when it is pulling in the pre-fit partition for the DDR4 EMIF.
