SO
8 years agoQuartus Design Partitions Crash - SR 00325624
This a continuation of SR 00325624. I'm trying to use Design Partitions to route a timing critical block containing a hard IP PCIe and DDR4 controller but when I reach the fit step, Quartus crashe...
SO
8 years agoDid Project-> Clean. No Change.
I realized a lot of .db files were not removed with the clean so I deleted them manually. I then had to fight through some weird pin assignment issues that came up related to the DDR4 EMIF but ended up at the same point. A couple times the fitter just said there was an error and gave no details or crash notice. The overriding theme of the errors is that Quartus is trying to place a duplicate pin/pll in the same location then complaining there's an error.
