Quartus crashes crashes when open dialog box
- 4 years ago
At least on my machine Windows 11 this is caused by Microsoft OneDrive.
Specifically when Microsoft OneDrive is set up to sync the "Desktop" folder. If I disable syncing of the desktop folder it works!
Hope this helps somebody else.
- GregMaynard4 years ago
I confirmed this was my issue as well. For those not sure how to configure OneDrive for this:
1) From File Explorer, right click on OneDrive in the Navigation Pane (left side of window where My Computer is)
2) From context menu select OneDrive->Settings
3) Click on the Backup tab and then Manage backup button
4) Click the Stop backup link for Desktop and then click Stop Backup
5) Close the window, setting is now applied, Quartus should be good. This worked for me with version 21.1.
- JCinVA4 years ago
Thank you, Shane, I can confirm that works. Windows 11. Remove Desktop from the OneDrive synch and the Open Project dialog will not crash.
