Quartus crash with "Internal Error: Sub-system: THR"
- 6 years ago
Hi, I actually solved the problem yesterday.
My compile system uses Lustre filesystem. The filesystem setup was a bit broken, and it was returning ENOSYS for fcntl(..., F_SETLK, ...) call.
After fixing the filesystem, compilation works perfectly.
Here is the script I used to debug:
#include <sys/types.h> #include <sys/stat.h> #include <fcntl.h> #include <stdlib.h> #include <stdio.h> #include <errno.h> int main() { int fd = open("a.txt", O_RDWR); if (fd == -1) { printf("open error (errno=%d)\n", errno); exit(1); } struct flock lock; lock.l_type = F_WRLCK; lock.l_whence = SEEK_SET; lock.l_start = 0; lock.l_len = 1; int ret = fcntl(fd, F_SETLK, &lock); if (ret == -1) { printf("fcntl error (errno=%d)\n", errno); exit(1); } printf("no error\n"); return 0; }If someone get "fcntl error (errno=38)", that's the problem.
Can you help to provide all the neccessary file (i.e Kernal *.cl files and etc) that were able to duplicate the error above? We will try in our side to see if this can be duplicated. From there, we will try to get a workaround for you if they are.
Hi, I sent you a message.
You can compile with "make" command inside __all___workspace directory.
Note that Intel® Acceleration Stack Version 1.2 should be installed and environmental variable FPGA_BBB_CCI_SRC should point to intel-fpga-bbb. (e.g., /home/heehoon/intel-fpga-bbb)
