13 years ago
Quartus, compile project, fitter, internal error
I get this error when compiling standard configuration - stage Fitter (Place&Route)
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/altera_arch_common/altera_arch_wire_maps.c, Line: 1546
Internal Error
Stack Trace:
   0x1f6eec: _vpr_qi_jump_to_exit + 0x64 (fitter_vpr20kmain)
   0x2b9162: _aa_pl_global_create_initial_placement_hints + 0xad (fitter_vpr20kmain)
   0x2b919b: _vpr_exit_at_line + 0x37 (fitter_vpr20kmain)
   0x2323da: _handle_assertion_failure_stripped + 0x25 (fitter_vpr20kmain)
   0x1d172c: ___sse2_available_init + 0x82728 (fitter_vpr20kmain)
    0x20177: _Dinkum_std::vector<_Dinkum_std::set<int,_Dinkum_std::less<int>,MEM_STL_ALLOCATOR<int> >,MEM_STL_ALLOCATOR<_Dinkum_std::set<int,_Dinkum_std::less<int>,MEM_STL_ALLOCATOR<int> > > >::_Insert_n + 0x2a7 (fitter_vpr20kmain)
    0xf3838: _aa_rt_wire_maps_update_with_current_routing + 0x88 (fitter_vpr20kmain)
    0x17c3d: _aa_rt_update_wire_maps_update_after + 0x7d (fitter_vpr20kmain)
    0x2d2ff: _aa_rt_timing_tamer_has_router_converged + 0x32f (fitter_vpr20kmain)
    0x2b66c: _vpr_qi_thr_mutex_destroy + 0xfc (fitter_vpr20kmain)
    0x146d3: _aa_fsda_router_compute_pin_connection_delay_chain_groups + 0x83 (fitter_vpr20kmain)
   0x128ed4: _aa_route_alg_perform_timing_driven_route + 0x24 (fitter_vpr20kmain)
   0x11584a: _aa_route_try_route + 0x6a (fitter_vpr20kmain)
   0x110c5e: _Dinkum_std::vector<_Dinkum_std::_Hash<_Dinkum_std::_Hmap_traits<int,int,_Dinkum_std::hash_compare<int,_Dinkum_std::less<int> >,MEM_STL_ALLOCATOR<_Dinkum_std::pair<int,int> >,0> >::iterator,MEM_STL_ALLOCATOR<_Dinkum_std::_Hash<_Dinkum_std::_Hmap_traits<int,int,_Dinkum_std::hash_compare<int,_Dinkum_std::less<int> >,MEM_STL_ALLOCATOR<_Dinkum_std::pair<int,int> >,0> >::iterator> >::resize + 0x18e (fitter_vpr20kmain)
   0x12e22b: _cl_free_do_clustering_short_life_data + 0x15b (fitter_vpr20kmain)
   0x11cd36: _aa_flow_fit + 0x66 (fitter_vpr20kmain)
   0x10dc8d: _vpr_main_internal + 0x2ad (fitter_vpr20kmain)
   0x13b35a: VPR_QI_FACADE::vpr_qi_main + 0xfa (fitter_vpr20kmain)
    0x2cfaf: _fitapi_run_vpr + 0x6f (fitter_fitapi)
    0x38374: FITCC_EXPERT::run_vpr + 0xf4 (FITTER_FITCC)
    0x39f5f: FITCC_EXPERT::place_and_route + 0x13f (FITTER_FITCC)
    0x3bb1d: FITCC_EXPERT::invoke_fitter + 0x64d (FITTER_FITCC)
     0x1536: _farm_execute + 0x206 (fitter_farm)
     0xa26b: fmain_start + 0x69b (FITTER_FMAIN)
     0x7835: qfit_execute_fit + 0x195 (quartus_fit)
    0x1179b: QFIT_FRAMEWORK::execute + 0x4ab (quartus_fit)
     0xfbb1: qexe_get_tcl_sub_option + 0x1641 (comp_qexe)
    0x1203b: qexe_process_cmdline_arguments + 0x3cb (comp_qexe)
    0x12123: qexe_standard_main + 0x83 (comp_qexe)
     0xb5be: qfit_main + 0x5e (quartus_fit)
     0x4d41: msg_main_thread + 0x11 (CCL_MSG)
     0x1be8: _thr_final_wrapper + 0x8 (ccl_thr)
     0x5425: msg_thread_wrapper + 0x85 (CCL_MSG)
     0x37f7: mem_thread_wrapper + 0x47 (ccl_mem)
     0x6051: msg_exe_main + 0x81 (CCL_MSG)
     0xb84c: _main + 0x1c (quartus_fit)
    0x13053: _memset + 0x15f (quartus_fit)
    0x133a9: BaseThreadInitThunk + 0x11 (kernel32)
    0x39ef1: RtlInitializeExceptionChain + 0x62 (ntdll)
    0x39ec4: RtlInitializeExceptionChain + 0x35 (ntdll)
End-trace
Please note: filename altera_arch_wire_maps.c
Quartus II 32-bit Version 12.1 Build 243 01/31/2013 SJ Full Version
Service Pack Installed: 1
Windows 7 Home Basic x64
Help me please,
    Write a service request. It is very unlikely that somebody in this forum has internal knowledge about Alteras source code.
    try deleting the db and incremental_db directories and re-compile.
    If it still crashes, file a service request.
    Thank you for the replies. Deleting the db and incremental_db directories didn't take any effect. The Service Request to Altera has been sent. I continue to wait in anguish and incomprehension.
    Hi Ignat. If you want a quicker resolution, please send the archived design to cauduong@altera.com. To archive the design, have the project opened in Quartus II and then select Project -> Archive Project. The output file would be a <project_name>.qar file. Thanks, Cam
