10 years agoQuartus Compilation error
I am getting a compilation error in Quartus II as: error (12153): can't elaborate top-level user hierarchy What is the possible cause? I have an always statement in my code as below: always @ (posedge clk or posedge reset or posedge enable) does this creating the problem? Please any one can help?2 Replies
Are you sure thats the only error?
Please post the full code and all errors (not just the final one). - Altera_Forum
Hello nazmulece08,
you should only use two posedges, clk and reset, a ff enable is not edge triggered: reg ff; always @ (posedge clk or posedge reset) begin if (reset) begin ff <= 1'b0; end else begin if (enable) ff <= data; end end But it seems that there is at least one more issue with your code.
