8 years agoQuartus_cdb (17.1/18.0) crashes while generating VQM for StratixV for a simple adder
Hi All,
I am using Quartus17.1 as well as Quartus 18.0 quartus_cdb crashes with following error only when StratixV family is used: *** Fatal Error: Segment Violation at (nil) Module: quartus_cdb Stack Trace: 0xbbd90: DEV_DEVICE::get_pad_info() const (ddb_dev) End-trace The verilog file, Add_24Ux24U_24U_4.v :# ########################## module Add_24Ux24U_24U_4 ( in2, in1, out1 ); input [23:0] in2, in1; output [23:0] out1; wire [23:0] asc001; assign asc001 = +(in2) +(in1); assign out1 = asc001; endmodule# ######################## The tcl file (syn.tcl):# ######################## load_package flow load_package report load_package sdc set module "Add_24Ux24U_24U_4" proc syn { module family verilogInput} { set proj [project_new -overwrite $module] set_global_assignment -name FAMILY $family set_global_assignment -name DEVICE Auto set_global_assignment -name VERILOG_FILE ${module}.v set_global_assignment -name NUM_PARALLEL_PROCESSORS 2 set_instance_assignment -name VIRTUAL_PIN ON -to in* set_instance_assignment -name VIRTUAL_PIN ON -to in* set_instance_assignment -name VIRTUAL_PIN ON -to out* set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top execute_module -tool map execute_module -tool fit execute_module -tool cdb -args "--vqm=${module}.vqm" project_close } syn $module "StratixV" $module# ######################## Command used to run > quartus_sta -t syn.tcl Please let me know any solution to this issue. Thanks, Srinivasa1 Reply
Contents of cr_ie_info.json
{ "system" : { "platform" : "linux64", "os_name" : "Red Hat", "os_version" : "" }, "error" : { "executable" : "quartus_cdb", "comment" : "not_applicable", "error_message" : "Segment Violation at (nil)", "source_file" : "unknown", "line" : "0", "stack_trace" : "\t0x7f387c125d60: ddb_dev + 0xbad60 (_ZNK10DEV_DEVICE12get_pad_infoEv + 0)\n", "subsystem" : "unknown" }, "quartus" : { "quartus_bits" : "64", "version" : "15.1.0", "build" : "185", "edition" : "Standard Edition" } }
