18 years agoQuartus Can't scan device
I have a custom PCB with the altera epm7064s chip. The chip was programmed and the circuit worked but after a little while one of the capacitors used for a 555 timer blew. Since then the timer output has been a little distorted (as expected) but when the button to trigger the altera chip is pressed nothing happens. So I plugged the byteblaster back in, opened Quartus to check the program. When I clicked auto detect, i get the following message:
''Unable to scan device chain. Can't scan JTAG chain." I believe something may have happened to the chip when the capacitor blew. Is this a correct assumption and if so is there anyway of verifying this? Thanks Joe
