17 years agoHi Frank,
Have you found a solution to this problem? I have similar problems using SFL in my design: Error: Pin Top|asmi_inst~ALTERA_SCE is incompatible with I/O bank 1. It uses I/O standard 2.5 V, which has VCCIO requirement of 2.5V. That requirement is incompatible with bank's VCCIO setting or other output or bidirectional pins in the bank using VCCIO 3.3V. Thanks
