10 years agoquartus_asm: Error in merging. Locked bit differs
I have a Stratix 4 project based on several iterations of the incremental compilation design flow. Each stage exports a QXP file and the final project consists of a single imported QXP file and an SD...
10 years agoThanks for the reply. I figured as much and opened a ticket with Altera support. I probably should have mentioned that in the original post...
I was more or less wondering if anyone had seen this before or knew of a workaround. Again, I probably should have mentioned that...
