Erfan
3 years agoQuartus "abort (core dumped)"
Quartus Prime Pro Edition is installed successfully on our server running Rocky Linux as a part of Intel FPGA SDK for OpenCL. The Quartus software is not working and throws an “abort (core dumped)” error when trying to launch the software. Attached is the output from strace.
Can someone help identify the issue?
Thanks!
- hareesh
i want to know some more information from you.
actually you said when lunching the software getting error, but which software are you trying to lunching and what procedure are you following to lunch the software. pls share those screen shots.
Thank you.
- hareesh
any update?
- Erfan
Thanks for your reply! The issue is fixed.
- hareesh
thanks for replay. so, i am closing your case.
