16 years agoQuartus 9.1 SP1 POF file generation
Hi All,
Has any one tried creating a POF file for the following setting using Quartus 9.1 SP1. Devices: EP2AGX125EF29C6ES CFI flash size: 512 MB Mode: Fast passive parallel. I am able to generate a POF file using the COF shown below only with 9.0 SP2.
<?xml version="1.0" encoding="US-ASCII" standalone="yes"?>
<cof>
<eprom_name>CFI_512MB</eprom_name>
<output_filename>test.pof</output_filename>
<n_pages>2</n_pages>
<width>1</width>
<mode>6</mode>
<sof_data>
<start_address>00640000</start_address>
<end_address>00C4A78F</end_address>
<user_name>Page_1</user_name>
<page_flags>2</page_flags>
<bit0>
<sof_filename>test.sof</sof_filename>
</bit0>
</sof_data>
<sof_data>
<start_address>00020000</start_address>
<end_address>0062A78F</end_address>
<user_name>Page_0</user_name>
<page_flags>1</page_flags>
<bit0>
</bit0>
</sof_data>
<version>4</version>
<options>
<map_file>1</map_file>
<option_start_address>18000</option_start_address>
</options>
</cof>
The above COF code is from Altera arria II gx development kit. I tried the same with 9.1 and 9.1 SP1, but both versions could not generate a POF file. The error is "Size of files(s) in CFI_512MB exceeds memory capacity". Am I doing some thing wrong? Thanks, Kumaran
