15 years ago
Quartus 9.1 PCIe pinout fiasco..
Anyone else get bit by this?
Quartus II Mapping Issue with PCI Express (PCIe) Interfaces Using the
Hard IP Block
The Quartus II software versions 9.1, 9.1 SP1, and 9.1 SP2 incorrectly allow logical
channel 0 to be placed in any physical channel for ×1 and ×4 PCIe Gen1 interfaces
with the hard IP block. For correct operation with the hard IP block, logical channel 0
must be placed in physical channel 0.
This issue is fixed in the Quartus II software version 10.0; however, Altera
recommends upgrading to the Quartus II software version 10.0 SP1. If you have
already designed or fabricated your boards using the incorrect mapping, file a service
request using mysupport.altera.com for assistance to remedy this problem
My board is built and assembled already.
I spent the last two weeks trying to figure out why my PCIe express core wouldn't work till I found this in the errata. When I compile it under 10.x it now errors out on the pins I chose for PCIe.
Yes, I've logged this with Altera support. The response was effectively "I don't see a problem, your design compiles fine in Quartus 9.1".. Sigh...
If anyone has received a coherent support response on this issue, please share it.
I'm hoping I can use the soft PCIe core to work around this. Bet I have to pay for it.
