10 years agoQuartus 9.1 doesn't fit SCFIFO into M9K blocks, it prefers LEs. Why?!
Hi All, I've used the project Nios II UDP Offload Example (http://www.alterawiki.com/wiki/nios_ii_udp_offload_example) on a Cyclone III dev kit, using Quartus 9.1. It seems to work well. ...
10 years agoHi Tricky,
adding synthesis attributes, as you suggest, works perfectly. I modified the code (altera_avalon_sc_fifo.v) from this reg mem ; to this (* ramstyle = "M9K" *) reg mem ; Thanks again for your help! Best regards.
