10 years agoQuartus 9.1 doesn't fit SCFIFO into M9K blocks, it prefers LEs. Why?!
Hi All, I've used the project Nios II UDP Offload Example (http://www.alterawiki.com/wiki/nios_ii_udp_offload_example) on a Cyclone III dev kit, using Quartus 9.1. It seems to work well. ...
10 years agoThere are synthesis attributes you can use to specify what type of ram to use.
http://quartushelp.altera.com/15.0/mergedprojects/hdl/vlog/vlog_file_dir_ram.htm
