10 years agoQuartus 9.1 doesn't fit SCFIFO into M9K blocks, it prefers LEs. Why?!
Hi All, I've used the project Nios II UDP Offload Example (http://www.alterawiki.com/wiki/nios_ii_udp_offload_example) on a Cyclone III dev kit, using Quartus 9.1. It seems to work well. ...
10 years agoI'd like add only one thing, for the second project, the one with the reduced logic.
--- Quote Start --- I made another project, just a test, reducing the logic of my original project. At the end of compilation I saw that Quartus was able to fit scfifo into M9ks. Scfifo took 4 M9Ks, and the design overall 123 M9ks. --- Quote End --- In this case, the report (Fitter-> Resource Section -> Ram Summary) shows scfifo memory type is AUTO and not M9K. Since scfifo is defined into the file altera_avalon_sc_fifo.v, is there a directive to force type memory to M9K to have always scfifo into this kind of blocks?
