16 years agoQuartus 9.0 SP1 program crashes
All,
Any request to print, print preview or set up a page causes a program crash *** Fatal Error: Int Divide By Zero Current editor: GED Module: quartus.exe Stack Trace: 0x3ae81: DrvQueryJobAttributes + 0x5da8 (OPHC_UI) 0x3e4d7: DrvQueryJobAttributes + 0x93fe (OPHC_UI) 0x6b25: ML_DllInitialize + 0x87e (OPHC_UI) 0x6d54: DrvDocumentPropertySheets + 0x1db (OPHC_UI) 0x15f4c: DocumentPropertySheets + 0x141 (WINSPOOL) 0xe310: Ordinal212 + 0x21e (WINSPOOL) 0x3930: PrintDlgA + 0x452 (COMDLG32) 0x353b: PrintDlgA + 0x5d (COMDLG32) 0x98823: DLLatmain12 + 0x6add3 (edt_ged) End-trace This is a 32bit version installed on a Vista machine. I used to be able to work around this by printing to an Adobe printer. Now it does not work at all. Does not matter what printer is set as default. Any ideas? Daniel
