17 years ago
Quartus 8.0 on Suse 11
Hi all,
I just installed Quartus 8.0 on Suse 11 evrything went cool and fine but i am not able to install usb-blaster drivers i.e., i followed therads mentioned here by adding usbfs /etc/fstab and writing 40-permission.rules in rules directory. USB blaster got recongnized but i get error
Info: Started Programmer operation at Sun Oct 19 04:23:34 2008
Error: Unexpected error in JTAG server -- error code 89
Error: Operation failed
Info: Ended Programmer operation at Sun Oct 19 04:23:34 200
and sof doesnt download,
i think suse11 uses udev and was not able to follow altera's red hat guide as there was no hotplug thing...........
does anybody have any ideas regarding this...........:confused:
pls help me on this
    I am not sure if SUSE 11 uses udev file system but if it does, then you should change the permissions by modifying /etc/udev/permissions.d/50-udev.permissions file (usbblaster:root:root:0666).
    thank you vizzee i did just the same and olla it worked, thank u very much:D, one more thing i had to do is remove usbfs with noauto argument and add dev mode 666
    I have a customer using Suse 10.1, not 11.0. There is a udev directory in a different location: /etc/udev/rules.d
    They changed the permissions on the 50-udev-default.rules and 32-altera-rules files contained in this directory, but it did not resolve the problem.
    Any recommendations or ideas?
    I've been using Quartus on Suse 11.0 for a while. I installed Suse 11.1 today on a new computer and Quartus gives some error that it can't use the Xserver because the protocol isn't defined. Did I forget to do something basic?
    gtnash, i had the same problem after installing on Suse 11.1. try calling: xhost +
    this will allow all clients (including Quartus) to connect to your X server
