10 years agoQuartus 7.2 not detecting USB blaster from windows 7 !!
can you please help me out.. My USB Blaster is not shown in programmer window I'm using Quartus 7.2 DE2 kit OS : windows-7 32 bit.. I installed the driver from drivers/usb-blaster of q...
10 years ago --- Quote Start --- I believe the QII 7.2 does not support Win7 OS. You can double check on the QII 7.2 release note on the supported OS or check Altera web on this. --- Quote End --- yes.. it does not support. but again problem arises with Q13.1 also.. it pops up window saying "device support not installed" in same win7-32bit. even if everything is properly connected. please help.
