18 years agoQuartus 7.1, 6.1 Debian 4.0 ETCH Installation
Hello all,
I'm a bit disappointed about Altera Linux policy. I'm a proud owner of DE2 Altera's Development and Educational board. My operating system is Debian/GNU Linux 2.6.21-1-686 ETCH 4.0 version I was trying to install Quartus II in several ways: 1) Using Wine -> Quartus 6.0 Full Web Edition crashed after 15 minutes of work (setting Pin Assignment according to the starting VHDL tutorial). After that I can't start the program again. Moreover there is no possibility to install USB Blaster drivers for Wine. :( . 2) Trying to download Quartus II 6.1 and 7.1 and install it according to the receipt given for Ubuntu 7.04 : 00) before everything you have to install tcsh and csh 01) cd /bin 02) mv csh chs_ 03) ln -sf tcsh csh 04) cd your_quartus_installation_files 05) ./install 06) cd your_devinfo_installation_files 07) ./install 08) cd /bin 09) ln -sf bash sh 10) export QUARTUS_ROOTDIR=your_quartus_path 11) cd your_nios2eds_installation_files 12) ./install 13) cd /bin 14) mv csh_ csh 15) ln -sf dash sh 16) edit /etc/udev/rules.d/40-permissions.rules and add to the end of this file : # Altera USB-Blaster BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", SYMLINK+="usbblaster" I haven't use the /opt/altera7.1/quartus7.1 directory , but my home directory (I haven't got free space in /opt dir) /home/majess/altera7.1/quartus7.1 I've also installed the devinfo 1 and 2. After untarring the archives I've changed the ./install script and comment the lines responsible for "bindkey" command. Installation runs smoothly and everything looked OK. I've add to $PATH the /home/majess/altera7.1/quartus7.1/bin and I've set up the $QUARTUS_ROOTDIR as /home/majess/altera7.1/quartus7.1 I've only installed the tcsh .... without csh. When I give a command: ./quartus from my prompt I have the output: majess@lap-153:~/altera7.1/quartus7.1/bin$ ./quartus arch: Command not found. arch: Command not found. arch: Command not found. Unknown Linux processor MWARCH: Undefined variable. I was trying to search through the net about this error, so I've look into the qenv.csh script and add setenv QUARTUS_MWWM allwm in the section: # This is the case for a non-supported Linux distribution. We don't prevent Quartus II # from running on this distribution, but we don't do anything special either. Individual # users may need to set QUARTUS_MWWM, LD_ASSUME_KERNEL, etc. as needed. if (! $?QUARTUS_MWWM ) then setenv MWWM allwm setenv QUARTUS_MWWM allwm endif I've run the script again and it shows the same problem with arch: Command not found. arch: Command not found. arch: Command not found. Unknown Linux processor MWARCH: Undefined variable. :(. I've run the ./check_patches from adm directory but it shows the same. Any Ideas? Help? Regards, Lukasz MAjewski I've ask Altera's supprot about supporting linux for the Quartus II Web Edition, but they of course said like always "YES we have some plans about that, but decision hasn't been made." (I've had the same reply for the same question in late January) BTW. Xi....x company is offering WebPACK ISE web edition for linux sine 2005 :(
