Quartus 22 Max V cpld development boar
Hi I have the MAX V development board. I would try to use for design and tests. I install the Quartus 22 but when I made a new project the development board is not eligible. Then I search for the design kit and I found the version 11, then I sear for the Quartus 11 but I only found the quartus 13 (Quartus-web-13.1.0.162-windows). The quartus 13 installer doesn't run in windows 10.
Do you know the way to use the develompent board for max V?
Martin
- _AK6DN_
Well, I have 13.0sp1 QuartusII Web installed on my Win10pro64b system (now at 22H2) for quite a while, and it works just fine.
Altho I don't specifically use MAXV devices, I see that the device assignment window allows for selecting a large variety of MAXV chips.
You can get the 13.0sp1 (or 13.1, but I don't use that version) Windows installer from here:
and install with the relevant device support files.
What version of Win10 are you using?
- MartinE
Hi, I have the Microsoft Windows 10 Pro, Versión 10.0.19045 compilation 19045. 64 bits, 22H2.
I download the three files and decompress. When I execute the setup.bat (as admin) or execute the QuartusSetup-13.0.1.232.exe file the result is the same, it appears to be freezed (attached image).
Do you have any test that I can do?
Martin
- _AK6DN_
Well, don't know what to say. I used this file:
QuartusSetupWeb-13.0.1.232.exe
And just run it as a normal user to install and let it prompt for privileges as necessary.
- MartinE
Hi, with the QuartusSetupWeb-13.0.1.232.exe I have the same throuble, the installer freezes and doen't work.
- _AK6DN_
Well, I suspect that their is something not quite right with either your Windows10 installation or the underlying hardware.
If you have another available Windows10 (or even Windows7 64b) that installer should work on those platforms.
I am at a loss of other suggestions, maybe others have some ideas.
- MartinE
Hi, I found the quartus 11.1 installer in a backup and it works.
Martin
- NazrulNaim_Intel
As per user "AK6DN" have provided the answer. I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
