rva1311
3 years agoQuartus 22 - University Program VWF - Ouputs stays to an undefined state
I try to use Quartus 22.1 on Linux for the target 5CSEBA6U23I7.
Simulations work when I use Tool > Run Simulation Tool > RTL Simulation.
But when I want to simulate a University Program ...
IntelSupport
Contributor
3 years agoHave you established any output in the waveform window?
You may need to add node for output using node finder by right click --> insert node or bus --> choose your input/output
Any snapshot on the issue maybe if possible?
- rva13113 years ago
Yes I had added each input/output before to launch the simulation. The output stays just to undefined.
