Quartus 20.1 evaluation newproject wizard help
I am have installed Quartus STD 20.1 version, & continued using Evaluation.
While creating new project wizard for Cyclone5 5CSEBA6U23I7, after click on finish, software not responding. I have seen same issue in Quartus lite 20.1 & 19 version as well.
Question is : Do I am missing something after installation?
Thank You.
Hi Shintansh,
The issue is probably because you are saving you project files in Quartus installation path. By defaults the project location to C:\intelFPGA_lite\20.1 which is read-only. It should default to e.g. the Documents directory or require you to enter a path. In the new project wizard try to change to any new directory you want and create new project, it should be okay.
Cheers,
Syafieq
- SyafieqS
Hi Shintansh,
Cheers,
Syafieq
- SyafieqS
Hi Shintash,
Make sure you meet all the basic system and requirement for Cyclone V. Please refer to link below for details
https://fpgasoftware.intel.com/requirements/20.1/
Following are general methods what you should do:
1. Make sure your OS is up to date
2. Kill any heavy background running while using Quartus
4. Reinstall Quartus and relaunch
