Quartus 20.1 evaluation newproject wizard help
- 5 years ago
Hi Shintansh,
The issue is probably because you are saving you project files in Quartus installation path. By defaults the project location to C:\intelFPGA_lite\20.1 which is read-only. It should default to e.g. the Documents directory or require you to enter a path. In the new project wizard try to change to any new directory you want and create new project, it should be okay.
Cheers,
Syafieq
Hi Shintansh,
Cheers,
Syafieq
