Quartus 20.1.0 Synthesis of System Verilog Interfaces
I swear Richard, you are the only person that works at Intel! You've answered all of my questions over years.
The link is here, ends at 17.0:
https://www.intel.com/content/www/us/en/programmable/quartushelp/13.0/mergedProjects/hdl/vlog/vlog_list_sys_vlog.htm
It appears that Quartus does not synthesize interface logic consistently. The problem isn't with the usage of system verilog, since the design simulates fine.
- RichardT_altera5 years ago
Hi @bitstreamer
You mentioned that the Quartus does not synthesize interface logic consistently, may I further understand the issue behind?
I found that Quartus has interface template that you can use, perhaps you can try to synthesis using the Interface template provided, to check if the issue still persists?
1. In the new .sv file created, Right-click and scroll to Insert template
2. A window will pop up. Click SystemVerilog > Design Units > Interfaces
Interface Declaration Template:
interface <interface_name>(<port_list>); // Variable Declaration(s) // Modport Declaration(s) // Function/Task Declaration(s) // Always Construct(s) // Generate(s) // An interface cannot instantiate a module but it may // instantiate an interface endinterfaceModport Declaration Template:
// A modport limits the access to the objects in an interface. Each port // must correspond to an object in the enclosing interface. modport <modport_name>(<port_list>); // Examples modport slave(input clk, input sel, output byte data); modport master(input clk, output sel, input byte data);Fyi, we have a team of people working on Intel Forum, and I believe you will most likely find me or my colleagues, on questions related to Quartus tool. Perhaps you may help to share us your feedback regarding to the forum support for the past few years?
Richard Tan
