10 years agoquartus 2: can't determine definition of operator "*"
I've got this error for the following code: library IEEE; --use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_unsigned.ALL; use IEEE.STD_LOGIC_TEXTIO.ALL; use...
10 years agoThe problem you are having is not in the code in the first post - that code compiles fine (with some length missmatch warnings).
Please post the code you are working with now as it is clearly not the code in the first post.
