Quartus 2 64bit version 15.0.2
- 3 years ago
As the software has been provided, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
For the issue with the Platform Designer (PD) system, manually open the system in Platform Designer and regenerate the system. PD will let you know it is updating IP (if it can). If there are any system components that cannot be updated during generation, you might need to recreate them with the newer version available.
But you are also getting errors that the .qsf if unwritable. Check write permissions in your project directory. If you can't do writes, this will obviously cause a lot of issues.
