10 years agoquartus 2 >> qsys >> conduit signals export error
hi, iam using quartus prime 16.0 in my module ,,i got 3 signals in conduit interface and iam declaring 3 of them as(signal type) "export" ..but then following error is coming.. "" Erro...
9 years ago --- Quote Start --- Hi Matthew, I have the same problem and have not found any solution yet. I don't get this part: "When you are told to set the signal type to export you instead have to add the interface "conduit" and then drag and drop the signals into it after that when you click on the signals under the conduit and change their "signal type" the name you enter in the signal type box gets appended to the signal export name." Can you please elaborate it more? drag and drop to where? --- Quote End --- Yes, It's where you're creating the custom component, here you add the interface conduit and drag and drop the delay ctrl signals onto this interface. I found several posts where people had given up and just used 13.1 but I wanted to use Prime and the answer was in the documentation found here ftp://ftp.altera.com/up/pub/altera_material/15.1/tutorials/making_qsys_components.pdf . Also pay attention to how Qsys appends the name of the signals and make sure it matches your top level file.
