10 years agoquartus 2 >> qsys >> conduit signals export error
hi, iam using quartus prime 16.0 in my module ,,i got 3 signals in conduit interface and iam declaring 3 of them as(signal type) "export" ..but then following error is coming.. "" Erro...
9 years agoHi Matthew, I have the same problem and have not found any solution yet. I don't get this part:
"When you are told to set the signal type to export you instead have to add the interface "conduit" and then drag and drop the signals into it after that when you click on the signals under the conduit and change their "signal type" the name you enter in the signal type box gets appended to the signal export name." Can you please elaborate it more? drag and drop to where?
