Quartus 19.2 warning 20536: Programming file generation feature has been removed....
You can ignore this warning.
'The compilation finishes properly, and a .sof file is produced. I assume this would be related to a .pof file?' --- --- -- Yes, It is related to generate secondary programming files.The Programming File Generator separates the generation of configuration files with the generation of bitstreams that contain the design logic. This ability allows you to define flash partitions, and also generate several programming files simultaneously. The Programming File Generator tool is available in the Intel Quartus Prime Pro Edition software versions 18.0 and later. For details refer the links below,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an827.pdf
https://www.intel.com/content/www/us/en/programmable/documentation/ftt1513991830769.html
'What legacy .qsf settings does this warning refer to?' ------ --- -- It might be due to quartus update has done from older version by you.
Vicky
