Quartus 18.1 fitter crash
- 3 years ago
Hi Eugene,
Please let me know if you are able to resolve this using below suggestion.
Update:
I am able to pin down the IE is triggered during heuristic accounting of input pins to a cluster. This heuristic counting is used to generate packing that give more flexibility for router to resolve local congestions for outlier designs, so it should be generally safe to disable this. I have tried the INI to disable this algorithm and the design is able to compile successfully.
Here is the encrypted INI (copy and paste this ini in your qsf) for 21.1 std (encrypted INI support is only avaliable for 20.1std or newer) then recompile.
ini_password = 0f56f88f5713676e261178731ef27f42b49cd891b355d81b400032576444751330035221150003342320131030052576
How to create that post-mapped database?
- There is KDB for this but for some reason it is offline, thus I post it here. Let me know if this is not possible.
Method 1: Using a Quartus II Archive File
Use the following procedure to export a Quartus II design database that does not include design source files. This method creates one archive file that someone else can use to recreate the project and compilation results without the source HDL files.
1. In the Quartus II software, from the Project menu, choose Archive Project.
2. Enter an Archive file name. The default is the current revision name for the project.
3. Under Include the following optional database files, select one of the following options:
o If the option is available for your device family, select Version-compatible database files (For future versions of the Quartus II software). This option is typically not available for devices that include any preliminary information in the Quartus II software (that is, the newest device families).
o If the above option is not available, select Compilation and simulation database files (For current versions of the Quartus II software). Note that this archive must be opened in the same Quartus II software version if you want to preserve the compilation results from the database.
4. Click Add/Remove Files.
5. Highlight the design files that do you not want to include in the archive, and click Remove. To highlight multiple files at once, hold the Ctrl key and click on each one, or hold the Shift key to highlight a set of files. You can also sort by file type by clicking on the Type column header; this allows you to find all the HDL files easily. Note that you can also remove other large files from the archive to reduce the archive file size, such as .pof, .sof, .pin, and .rpt files. Do not remove any files from the db directory.
6. Click OK in the Archive Complete dialog box that appears. If you chose to create a version-compatible database, by default the archive process creates a copy of the database in a directory called export_db.
7. You can now send out the software-generated archive file with the name <archive file name>.qar.
