Quartus 18.1 fitter crash
- 3 years ago
Hi Eugene,
Please let me know if you are able to resolve this using below suggestion.
Update:
I am able to pin down the IE is triggered during heuristic accounting of input pins to a cluster. This heuristic counting is used to generate packing that give more flexibility for router to resolve local congestions for outlier designs, so it should be generally safe to disable this. I have tried the INI to disable this algorithm and the design is able to compile successfully.
Here is the encrypted INI (copy and paste this ini in your qsf) for 21.1 std (encrypted INI support is only avaliable for 20.1std or newer) then recompile.
ini_password = 0f56f88f5713676e261178731ef27f42b49cd891b355d81b400032576444751330035221150003342320131030052576
Hi Eugene,
Understood. Below are some updates and request answer from developer. Let me know if that is not possible
Update: This IE is triggered when clusterer is determining if the LAB is legal by counting the inputs. The code assumes the input counts should be back to zero when all blocks are removed, but that's not the case for this design.
Unfortunately, this design seems to hit a rare corner case. Without the actual design that contains the specific LAB that triggers the IE, it is hard to identify the root cause of this bad behavior. And without this information, there are no simple/safe workarounds to bypass this IE.
Questions:
Have this design ever compiled successfully before?
Does you try to compile the design using different seeds?
Does you see any User Error/Warning messages before the IE?
Are there any special netlist topology? (self feeding loops, special location constraints, etc)
Is it possible to to pass in a post-mapped database (archived qar file) without the source, so that we can run quartus_fit at our end?
- EugeneF3 years ago
Hello!
Yes, sometimes this design compilled succesfully. Then, after some minor changes, it compiles with this error. Then, after some other changes in other places (adding some extra registers for example) it again compiles succesfully, ets... It can be a "random" changes in different places, not connected to some particular place or block of the design.
Different seeds doesn't affect to the error. But different optimization settings (performance/power/area) sometimes help to eliminate error. (Or sometimes get it back)
There are no any Error messages before IE. Only some Warnings about severall unconstrained internall clocks in project.
There a no special location constraints. Only location for input/output pins.
How to create that post-mapped database?
