FPGADev
7 years agoQuartus 18.1 - ModelSim Starter 10.5b - IP-Core LPM_MULT (square) problems
I try to simulate a design with a LPM_MULT IP-Core in square mode. I'm able to compile the design but the simulator fails with the following error message: Error: (vsim-3389) mul_sqr.v(53): Port 'sc...
Vicky1
7 years agoHi,
For LPM_MULT IP-Core asynchronous clear, clock enable & synchronous clear are have optional support so either you comment those signals or instantiate an LPM_MULT function without the squaring function and use the same signal for both dataa and datab inputs since in squaring operation multiply 'dataa' input by itself.
refer the below solution & user guide,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_lpm_alt_mfug.pdf
Best Regards
Vikas Jathar
