PFong2
7 years agoQuartus 18.0 generates a different RBF file for each compile. What setting is causing this behavior? Please see details section
I have attached a qar file that was archived with Quartus 18.0. When we restored this project and compiled, we got a different RBF file than the original SRM_VENTNOR.rbf file that is attached. Each t...
SZack
7 years agoHi Vicky,
I am the Intel PSG FAE at Arrow that supports this customer and I could replicate the issue also but could not explain why this issue was happening. I looked at the "good" design to check the settings and didn't see anything different from the "bad" design.
Have you or your team had a chance to investigate why this one design from the customer gets different RBF files after each compile?
Steve Zack
Vicky1
7 years agoHi PFong2 & SZack,
Could you please check again by creating the fresh deign with all the files included in that erroneous design?
we are working on it & will let you know once we get any update.
Vicky
