PFong2
7 years agoQuartus 18.0 generates a different RBF file for each compile. What setting is causing this behavior? Please see details section
I have attached a qar file that was archived with Quartus 18.0. When we restored this project and compiled, we got a different RBF file than the original SRM_VENTNOR.rbf file that is attached. Each t...
Vicky1
7 years agoHi,
Thanks for the design.
I checked with your design & observed that .rbf files generated from this project shows equivalent by KDiff3 Tool even this project consists of PLL IP. so as you mentioned in your very first post , there might be some issue with that design.
let me check with my team since issue is replicated & get back to you.
Vicky
PFong2
7 years agoPlease double check the compiler settings between the two QAR files as well to ensure that it's not any compiler setting causing the issue. Thanks.
