PFong2
7 years agoQuartus 18.0 generates a different RBF file for each compile. What setting is causing this behavior? Please see details section
I have attached a qar file that was archived with Quartus 18.0. When we restored this project and compiled, we got a different RBF file than the original SRM_VENTNOR.rbf file that is attached. Each t...
PFong2
7 years agoI've uploaded the similar FPGA design (SRM_5000.qar) along with the output RBF file (SRM_5000.rbf). You will need to extract the SRM_5000.rbf file from the SRM_5000_RBF zip file.
Please restore this design and compile twice. A comparison of the two output RBF files will show that they are binary equivalents. Please investigate root cause of this issue. Thanks.
PFong2
7 years agoI attached it again. Please confirm you can download the SRM_5000.qar file.
